So I finally got around to installing my HID Retrofit on the projectors. I couldn't handle the horrible light output anymore. Originally it used the same resistor packs that many of us are familiar with from Retroshop with the exception that they are on a custom aluminum heat sink for longevity. But it's still 2 morimoto resistors per bulb on the 2015 (only 1 for the 2014) because the computer is so picky. I had one resistor go bad and Max with enlight was really great to deal with. Also being the ecodiesel I had some length issues with the harness that's built to go around the hemi cooling system, I was sent a new harness with longer battery leads no questions asked to help routing, and I got updated resistors when I had the one go bad. They are now a flat aluminum single resistor on a slightly larger heat sink. Price is about the same as the Retroshop kit but the heat sink and resistor longevity had me sold, and now with the custom resistor pack it's far superior to any system out there. Even with a large heat sink the mounting options are great.
he only offers 6000k bulbs but has an upgrade to a xb55 ballast that drops it to 4300k (OEM color for any other HID)
But will order custom color bulbs for additional cost but I think the intensity upgrade and color drop of the 55w ballast is all anyone needs.
The light looks great and the install other than harness being tight was absolutely fantastic. I'll Work on getting a discount code for everyone here. There was one on another gasser ram forum I found.
Max was really great to solve any issues I had and was very prompt to do so.
Though the length was probably partially my own fault because I'm so picky. I don't want to see any wires. AT ALL. Just because it's a Retro fit doesn't mean it needs to looked like something that was rigged up to Work on the truck.
And I followed Retroshops idea to stuff the ballasts and igniters into the projector headlight housing. Which works great.
Attached are a couple pictures of their new 2015 resistor packs on the heat sinks and a new LED fog kit I was just told they were working on.
Really good company and great Service. I am extremely happy and found the kit to be superior to others available.
