Been looking for a Rod Rack that spans across the bed behind the cab in the stake pockets. Came across several, both DIY and pro built. The nice ones are way out of my budget.
I'll only use this a few times a year for trips to the coast and Lake Erie. Decided to build one. Keep in mind my skills are elementary lol.
$35 with of steel. 1-1/2" square and 1-3/4" round tube, both 16gauge I believe. About 32' of it. Enough for 2 or 3 racks maybe. Not that I'll build more then 1 haha.
Cut out the stake pockets using a razorblade, scoring the outline until she snapped out. Outline is not actual hole size for some reason.
Cut the legs. 14" length. Just above the bed rails I cut 17degree angles to get it to follow cab lines and rise away from the back glass.
Tacked & test fitted.
Rough finish weld.
That's where I stand now. Cross bar and Rod holders coming soon. I'll also need to sleeve the base as the stake pocket is 1-1/2"x2" and my material is square 1-1/2". And need to figure out how to secure it through the access hole inside the bed as well. I'm thinking some kind of cam lock. Anyhow, I'll update as I progress. Thanks for looking.
-Brady
Rough finish weld.
-Brady
