I agree. Unless the filter head is warped and it's not making a good seal...or the filter is just defective (not a good seal, etc). Not much else that can be wrong.Seems like it could only be the o-ring not sealing, maybe it's a defective o-ring.
It does take a while for all the oil to drain. Not your typical Jiffy Lube stop. I removed the oil drain plug and let it drain while i was replacing my fuel filter. Just fyi do not wait more than 10-12k miles to replace the fuel filter. I only use very good quality diesel from the same station and my fuel filter was filthy at 17k. Also I noticed that it is 10.5 quarts oil capacity , but I only aded 9.5 and it showed full on the dip stick. One more quart and it would have been overfilled.I was told that on these engines the oil change takes a while to perform. Something about after pulling the drain plug that you have to let it sit and drain for 45 minutes then let it sit for a while after the initial fill of oil. They said it takes about 3 hours to do one??? Seems a little odd to me and they want about $180 to do an oil change.
Andy, did you check the oil level before or after the engine was started. If you checked it before starting the engine, the oil wasn't in the oil filter yet. I'm not sure what the filter capacity is.It does take a while for all the oil to drain. Not your typical Jiffy Lube stop. I removed the oil drain plug and let it drain while i was replacing my fuel filter. Just fyi do not wait more than 10-12k miles to replace the fuel filter. I only use very good quality diesel from the same station and my fuel filter was filthy at 17k. Also I noticed that it is 10.5 quarts oil capacity , but I only aded 9.5 and it showed full on the dip stick. One more quart and it would have been overfilled.
I did check it before and after. After the engine was started and ran for a couple of minutes, I stopped it and checked the level after a few minutes. With my first oil change I put 10.5 in there and after running the engine, the level was about1/4 inch above max, so I had to drain about a quart before it was at the normal level. But that is just my experience, so if you had 10.5 quarts in there it is a good idea to recheck it.Andy, did you check the oil level before or after the engine was started. If you checked it before starting the engine, the oil wasn't in the oil filter yet. I'm not sure what the filter capacity is.
I will defiantly keep that in mind whenever I get mine and do my first oil change.I did check it before and after. After the engine was started and ran for a couple of minutes, I stopped it and checked the level after a few minutes. With my first oil change I put 10.5 in there and after running the engine, the level was about1/4 inch above max, so I had to drain about a quart before it was at the normal level. But that is just my experience, so if you had 10.5 quarts in there it is a good idea to recheck it.
Andy did you ever get this figured out? Have the same problem! ThanksView attachment 609 Hello EcoDiesel owners! I have noticed that after changing my oil( done by me and done by the book and other helpful online videos) there is a leak right by the oil filter housing. I keep wiping it off and after a short drive, the oil is present again, as shown in the picture. Has anyone else had that happening? Any advises ? Thank you!
@TrevorB , O ring was in the wrong location of the oil filter capAndy did you ever get this figured out? Have the same problem! Thanks
@jdn112011 thag was the exact problem! Thanks for the info! Guess I’ll change my own oil from now on!@TrevorB , O ring was in the wrong location of the oil filter cap
That's the way to go! Was it dealer service or a individual Shop that did it wrong?@jdn112011 thag was the exact problem! Thanks for the info! Guess I’ll change my own oil from now on!
